zenon IEC870 driver does not set T_STD bit (bit 30) at zenon variables
The zenon IEC60870 driver does not set the status bit T_STD ("Standard time", e.g. winter time in Europe) - bit 30 - at the variable in zenon.
The issue was addressed in procedure evaluating the UTC time to local time. According if the time belongs to period of standard time or not the bit is set.
Note: this does not depend on the SU bit in the incoming tag CP56Time2a but only on the received date&time value.
The T_STD bit in general is actually some recurrent information to timestamp self. If the time is in summer or winter you can see on date.
Note: the T_STD is not particularly corresponding to the SU bit in ASDU types that use CP56Time2a.
Issue Number: 26039
Fixed on Date: 16.5.2012
Versions: 7.10 0 BUILD 5560
iec850 driver does not set T_STD bit (bit 30) at variables with timestamp from t-attribute (T_EXTERN)
Summary IEC61850 Client driver does not set the T_STD bit at the zenon variables getting external timestamp - from t-attribute (variables with FC= ST or MX, e.g. */stVal[ST]). The driver uses correctly T_STD bit but only by T_INTERN timestamps, not ...
iec870 driver does not transfer to SE new values of command variables if the old value had status bit OFF
Summary The IEC 870 driver does not update values of command variables in the Service Engine if old variable values have status bit OFF. This behavior has been modified. Description The IEC 870 driver does not update the values of the command ...
