zenon embedded Metadatabase editors (with Active X)
The solution consists of 2 points:
1) zenon has been extended by calling the garbage collector on closing screens.
2) The Manual Data Editor and the Metadata Editor are modified to dual controls (windows forms and Active X).
Fixed in:
- zenon Analyzer 2.10 SP0 Build 6482
- zenon 7.10 SP0 Build 6492
- zenon 7.11 SP0 Build 6490
Issue Number: 29615
Fixed on Date: 25.6.2013
Versions: zenon Analyzer 2.10 0 BUILD 7874 | 7.10 0 BUILD 6571
    • zenon to PAS-X MES connectivity solution
      Summary Bidirectional exchange of data between Werum PAS-X and zenon Description The Werum MSI Interface enables the bidirectional exchange of data between Werum PAS-X and zenon. Werum PAS-X can thus use zenon to directly access the production ...
    • zenon Service Engine freezes when process recorder is active
      Description The zenon Service Engine froze when the Process Recorder was active. The Service Engine froze because a Microsoft function runs in an endless loop. The issue has been addressed and an optimization call, which led to the issue, has been ...
    • Engineering Studio: Embedded help links are misinterpreted
      Description Links from embedded help in Engineering Studio to main online help do not work or end up in the wrong chapter. This problem is caused by a link parsing error. Solution: Update your zenon version to the latest build. Item ID: 253902 ...
    • Function "Execute VSTA Macro" is not executed in zenon 12 for converted projects
      Description When converting a project to zenon version 12, the "Execute VSTA macro" function is not applied correctly. The VSTA code is not executed. However, the same code is executed if it is part of the "ThisProject_Active" or ...
    • Machine Event Counters Report not working any more in zenon 12
      Description In Report Engine version 12, the reports "Machine Event Counters", "Over Revolutions on Load Shedding" and "Active Power on Load Shedding" no longer work after they have been updated from a previous version. The error states that the ...
