zenon Editor Output Window and substitution dialog. The screenname is missing if the linked symbol has invalid variable substitution and the question mark will be shown if the variable is invalid.
When a linked symbol has invalid variable substitution for example the variable didn't exist, then a question mark ? will be shown at the dialog for the substitution.
And when the zenon Runtime files are created there is a warning message in the Output Window but without the screenname. For Example Linked variable not found: Screen xxx ....
An issue was addressed to the behavior of those elements. Now, after implementing an additional routine the name of the invalid variable will be provided at the Dialog-Window for the substitution and the screenname will be provided at the Output- Window.
Issue Number: 32989
Fixed on Date: 19.11.2014
Versions: 7.50 0 BUILD 25796
    • Output window: "Report Viewer: export/print" function provides incorrect warning in the output window
      Summary The "Report viewer: export/print" function issues incorrect warnings in the output window. This has been fixed. Description Under certain conditions, the "Report viewer: export/print" function issues incorrect warnings in the output window. ...
    • if you delete the linked EQM then the 3D configuration can not opened anymore / pointer exception
      Summary The configuration of the 3D-Integration is no longer possible after deleting a linked EquipmentModel. This behavior has been modified. Description An Equipment Model that is linked to the 3D-Integration is deleted. As a result, the dialog for ...
