zenon Editor closes unexpectedly, when deleting a combobox list which is used in a report
When a "combobox list" is used in a cell of a Report Generator and this list is deleted the zenon Editor closes unexpectedly.
It's possible to delete drop down lists which are referenced in cells. The cells may show the selected entry but if you drop down the list is shown empty.
Issue Number: 24802
Fixed on Date: 10.11.2016
Versions: 7.60 0 BUILD 36068
FAQ: From a certain amount of connected Smart Clients the Smart Server closes unexpectedly, what can I do?
It is possible that the Smart Server closes as it runs out of possible memory address space for a 32-bit application. In this case use the Smart Server 64-bit version.
Deleting of an Referenced Smart Object Template causes Zenon to Crash
Under specific circumstance the zenon Editor closes unexpectedly.
Summary When clicking into a color palette grid cell and back to another project tree the zenon Editor could close unexpectedly. This behavior was only reproducibly when multi touch monitor and when Windows 8 as operation system was used. ...
