zenon Editor closed unexpected under specific circumstances.
It could occur that the zenon Editor close unexpected, when working with zenon 3D Configurator Tool and updating variables in the 3D Tool then reactivate at the zenon Editor another zenon project again.
An issue was addressed by reactivate an zenon project at the zenon Editor, when working with the 3D Configurator Tool on another zenon project. Now, when reactivate a zenon project at the zenon Editor the correct COM Object will be released an the zenon Editor will work as expected.
Issue Number: 38251
Fixed on Date: 16.5.2017
Versions: 7.60 0 BUILD 39532
    • zenon Runtime closed unexpected under specific circumstances.
      Summary When duplicating a zenon project, which includes an WPF element created with our zenon 3D configuration tool, it may happen that the zenon Runtime close unexpected when opening the screen with the 3D WPF element. DescriptionWhen duplicating a ...
    • Editor may stop responding under specific circumstances when the color picker is closed
      Summary When picking the color for a property using the color picker in the properties window under specific circumstances the editor may stop responding when the color picker is closed by clicking on another empty area in the screen Description When ...
    • Under specific circumstance the zenon Editor closed with unhandled exception.
      Summary The zenon Editor closed with an unhandled exception when undo a specific configuration of numerical elements. DescriptionThe zenon Editor closed with an unhandled exception when undo a specific configuration of numerical elements. Solution An ...
