zenon Editor close when creating zenon Runtime files for 6.20 SP4.
When selecting "Create files for: 6.20 SP4" at the zenon Editor and start to convert, after a couple of minutes – time depends on the project size - zenon Editor stops working and closes automatically.
An issue was addressed to the Message Control recipients. Now, the zenon Runtime files for zenon 6.20 SP4 can be created as expected and the zenon Editor will not be closed automatically.
Issue Number: 27047
Fixed on Date: 20.6.2012
Versions: 7.00 0 BUILD 1 | 7.10 0 BUILD 5560
    • FAQ: How to prevent corrupted files after power outage?
      Read the attached PDF files (English/German) for more information on how to set up your system to avoid corrupted files in case of an power outage.
    • In a specific case the zenon runtime may close unexpectedly when opening a Variable diagnosis screen.
      Summary If a project is engineered in zenon 7.10 editor and runtime files are compiled for an earlier zenon version, the targeted zenon runtime may suddenly close when opening a Variable diagnosis screen containing variables to display. If runtime ...
    • The editor may fail to create runtime files for converted projects
      Summary The editor may close unexpectedly or pop up an "unexpected file format" message when creating the runtime files in converted projects. Description The editor may close unexpectedly or pop up an "unexpected file format" message when creating ...
