zenon Editor – Styles. When changing the ‘Fill color’ of the ‘Fill style’, then the property ‘Gradient Color -> Automatic’ will be not updated as expected.
For a static element with fill options for example like for a created rectangle with property ‘Gradient color = Automatic’ selected and changing the value of ‘Fill color’ then the value of ‘Gradient color’ changes at the same time.
But, when changing the same behavior at a ‘Fill style’, the ‘Gradient color‘ property will be not updated automatically.
An issue has been addressed at the update cycle of the ‘Fill Style’. Now, the ‘Gradient color’ updates properly, when changing the ‘Fill Color’ on the styles itself.
A kind of workaround for updating the ‘Gradient color‘, when changing the property at the ‘Fill style’: Close and open the property window (clicking somewhere else and seeing other properties) and came back to the ‘Fill Style’, then the color will be also updated as expected.
Issue Number: 36023
Fixed on Date: 2.3.2016
Versions: 7.60 0 BUILD 36068
The “transparency gradient color” property for buttons may not be set in the Editor.
Summary It may not be possible to set the same value for the “transparency gradient color” and “transparency of the fill color” so that the first property value changes inadvertently in the Editor. DescriptionIt may not be possible to set the same ...
Set colors of color palette to zenon elements via API.
Colors in zenon are a 3-byte code of RGB values. The value #EB29D6 corresponds to a strong pink tone. If these colors are linked directly to a zenon object exactly this value is entered in the dynamic property of the element, screen, textcolor, ...
ALC Line can not be selected as Source for Alias if "Color from ALC" is set via Style
Description In Automatic Line Coloring the Screen Element Line could not be used as an ALC Alias Source if their property Color from ALC was set via Style. The issue has been addressed and the behavior is now as expected. To benefit from this fix: ...
