zenon Editor – language table. Opening the language table could cause a memory leak.
When opening the language table at the zenon Editor it may occur a memory leak of approximately 10 kb for each opening of the language table. Not reproducible with an empty zenon project.
An issue was addressed at the language table of the zenon Editor.
Issue Number: 29639
Fixed on Date: 15.11.2013
Versions: 7.20 0 BUILD 17768
save after interlock assignment(change) in symbol visibility setting causes zenon editor crash
Description If a symbol whose visibility has been assigned an interlocking is saved while the Interlocking is still selected, may the Engineering Studio cause to crash. This error has been fixed. To benefit from this fix: Update your zenon Software ...
Addin Services seem to cause Memory leak
Summary - Description - Information I suggested the customer to trigger a zenon function with a wizard inside the worker thread. Wizards do not have this issue since the appdomain is destroyed after finishing and the memory is released. I do not know ...
zenon Language Table issue – missing system text translation.
Summary Text generated by system will be not translated, although there is a corresponding entry in the language files. The displayed text is always in the zenon Runtime and Editor language, when modify a recipe and change the picture without save. ...
