zenon Editor – Integration- and Subproject constellation. Project parameters with substitution were not displayed proper.
Substitution: replaced project links were not performed on functions wherever the parameter contains a filter on projects.
An issue was addressed at the project filter of the integration project. Now, it works proper. The projects at the project filter of the integration project were recognized as estimated.
Issue Number: 26239
Fixed on Date: 17.11.2014
Versions: 7.50 0 BUILD 25796
Variable identification in the Variable Diagnosis screen cannot be translated in Subproject from Integration project
Summary In the Service Engine, not all variables are translated as configured in the Variable Diagnosis screen. This has been fixed. Description In the Service Engine, with Multi Project Administration, the identification for variables from the ...
Cel print with Switch language in Sub Project from Integration Project doesn’t work.
Summary Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified. Description In a project, the CEL is configured for ...
An integration project of version 7.10 does not show historical alarms of 6.51 subproject (subproject uses different server than integration project)
Summary An integration project with subprojects where subprojects have different project servers, running with older zenon version - due to a step-by-step update to 7.10, the integration project server is on zenon 7.10 and the other servers are on ...
