When adding a filter to a screen switch function, choose a fill color from the color palate or simple any color and export them via function and import them, then the default values for the fill color will be displayed again.
An issue was addressed at the property - fill color, respectively for the XML Import / Export function. Now, the property fill color is also configured for the XML Import / Export function as well for VBA.
Issue Number: 37146
Fixed on Date: 15.11.2016
Versions: 7.50 0 BUILD 32567
