For the cases when importing a new color palette with more colors than the existing palettes, then the already existing color palette will be amplify with the supplementary colors until the same amount as the new imported color palette. But it occurs that there is no color deposited however the new imported colors should be filled within ‘white’ color by default.
Now, when importing a new color palette which has more colors than an existing one, than the existing ones are filled/ supplemented with ‘white’ colors per default.
Issue Number: 35559
Fixed on Date: 13.11.2015
Versions: 7.60 0 BUILD 36068
