zenon crashes using Scheduler in Compatibility Mode
When using the Scheduler, the Service Engine (Runtime) crashes in compatibility mode. For example, Service Engine files are created in version 7.60 for 7.11. The server is started in version 7.11, the client in version 7.60. If an entry for the Scheduler is created on the client and then switched to the Scheduler on the server, a crash occurs. If a CE device is used, the crash does not occur, but the entry in the Scheduler is discarded.
This error has been fixed.
  • Update your zenon Software Platform to the latest build of zenon 7.11 or higher.
Item ID: 155653
Version: 8.00 Build: 53129
Version: 7.60 Build: 52515
Version: 7.50 Build: 54309
    • Scheduler in compatibility mode isnt working
      Description Creating schedules does not work in compatibility mode. For example, Service Engine files (Runtime files) are created in version 7.60 for 6.22 SP1. The server is started in version 6.22 SP1, and the client is started in version 7.60. If ...
    • zenon stops working when using Scheduler in compatibility mode
      Summary In a network setup where the server uses an older zenon version (7.10 and older) than a client (e.g. 7.60) then the Server may stop working when it tries to open the Scheduler screen after a schedule has been created on the client. The client ...
    • FAQ: How does COPA-DATA ensure the Product compatibility with Microsoft Operating System Patches? How can I get information about compatibility issues?
      As a general rule, COPA-DATA recommends keeping the operating system current and installing the latest security updates. Check updates on your own system(s) before installation for possible interactions with the zenon Software Platform. The current ...
