zenon 14/12 - Engineering Studio Crash restoring Workspace
In zenon 12, trying to
restore a workspace from a previous version can lead to a crash. This is
related to the handling of certain constellations in the alarm configuration.
To avoid the error a workaround exists: The alarm areas are exported in the
source version and deleted. After restoring the project in version 12, the
alarm areas are imported again.
This error has been fixed.
Workspaces from previous versions can be restored correctly in zenon 12 without
workaround again.
- Update your zenon Software Platform to the
latest build of zenon 12 or higher.
Item ID: 267349
Version: 12.00 Build: 159727
Checklist: Engineering Studio cannot start or closes unexpectedly
Checklist: Workspace/Project cannot be created, loaded or backed up
Checklist: Distributed Engineering – Engineering Studio cannot connect to the Project Database-Server / Elements cannot be checked-in/out
Time estimate: 45 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. Checklist usage: #. [Quick ...
