zennetsrv closes unexpectedly without an error message when receiving a specific invalid message
The zenon network service (zenNetSrv.exe) is closed unexpectedly when receiving invalid messages. This has been fixed.
If in a zenon network the server receives invalid messages, the zenon network service (zenNetSrv) is closed unexpectedly. No error message is displayed. In this state the Service Engine can no longer provide clients or the Secondary Server with information and the Service Engine must be restarted in order to restore service.
This error has been fixed. Invalid messages no longer cause the zenon network service to be terminated.
Item ID: 271515
Version: 12.00 Build: 206562
    • zennetsrv closes unexpectedly when receiving other invalid message(s)
      Summary The zenon network service (zenNetSrv.exe) is closed unexpectedly when receiving invalid messages. This has been fixed. Description If in a zenon network the server receives invalid messages, the zenon network service (zenNetSrv) is closed ...
    • AccessIec870Sl: Gateway Closes with exception after receiving an invalid message
      Description If in the Process Gateway the IEC870Sl receives a specific invalid message, it is closed with an exception. This behavior has been changed. The IEC870Sl has an improved detection for invalid messages. Invalid messages are ignored. To ...
    • The DNP3_TG driver closes unexpectedly without an error message after receiving a specific response to a file transfer request.
      Summary The DNP3_TG driver closes without an error message when a specific outstation reports a file size 0xFFFFFFFF in a response to a file open request. In this particular case, the outstation reports 0xFFFFFFFF to indicate not a file size of 4GB ...
