zenDrvOpsManager keeps running when it is not needed anymore
When closing the Engineering Studio,
zenDrvOpsManager continues to run in the same Windows user context. Therefore, another operating system user cannot open
the driver configuration on the same PC until this process is terminated. This is
also true for the Service Engine.
This behavior has been modified: The EngineeringStudio now starts drivers directly. The zenDrvOpsManager
is no longer used. This allows different users to start the EngineeringStudio in succession without having to terminate the zenDrvOpsManager
first.
Recommendation for the Service Engine:
Log off the current operating systerm user before another user starts the Service Engine. This
prevents drivers from being started in the context of another user.
higher.
Item ID: 264595
Version: 12.00 Build: 159727
Version: 11.00 Build: 157700
Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
