The “Y-Axis from” setting did not work correctly in the Extended curve list of the Extended Trend screen. When setting the "Axis from" value to a value lower than the current "Axis from" value, no change occurred.
The issue has been addressed and the “Y Axis From” behavior is now as expected.
Item ID: 294012
Version: 14.00 Build: 350309
