In the XML export in general, regardless if this is e.g. a XML Export of a variable in the editor or a XML Export of a Recipe of the Recipegroup Manager in the runtime, the number of decimals for values is limited to 6, even when more decimals are specified for double precision floating point values (LREAL).
An issue has been addressed in XML export where the number of decimals for double values was restricted to a maximum of 6.
Now the correct number of 10 decimals are used in XML export.
Issue Number: 33488
Fixed on Date: 22.10.2015
Versions: 7.50 0 BUILD 25796
