If the Export archives function has a setting to export the archive in dBase, SQL or XML format and these functions are exported as XML, and then imported again, the exported format is set to CSV.
An issue was addressed at the properties for export type. Now, the properties for the export type and the automatic name generation get exported and imported as accepted and keeps there settings.
Issue Number: 35606
Fixed on Date: 3.11.2016
Versions: 7.50 0 BUILD 32567
