XML export and (re)import of command groups removes wildcard-based interlocking variable entries.
In Command Processing for all variables – response, command and interlocking – the wildcard '*' is allowed (and recommended).
During XML-export and (re)import the entries about interlocking variables are removed if had the wildcard.
Introduced separate property in xml that does not require a variable, but uses only the string. Assured that on import also a real variable is linked correctly.
Issue Number: 32067
Fixed on Date: 25.10.2016
Versions: 7.60 0 BUILD 36068
