WVS: Input misplaced when using RGM in a worldview
In WVS, the input field for values in the worldview screen is placed incorrectly under certain conditions. This has been fixed.
In WVS, the input field for values in a worldview screen may be positioned incorrectly. In this case, the input field is displayed outside the table or element in which a value is to be edited. This happens with direct entries and with entries via a keyboard screen as well.
This occurs with entries:
  • in the RGM recipe value table
  • for elements with the setting “Write setvalue via: Element”
This error has been fixed. The input field is positioned correctly again.
Item ID: 280055
Version: 14.00 Build: 257014
