WVS: Authorization levels from group don't work
User levels are not applied correctly in
the Web Visualization Service (WVS). When a user clicks on a protected
button, he is rejected even if his user group has the appropriate rights.
This behavior has been changed. The user
levels of the user groups are also applied correctly in WVS.
higher.
Item ID: 258518
Version: 11.00 Build: 112904
[User Administration] Current authorization group 1-4 variables bits are not correctly set in Service Engine v10 32-bit when a user with authorization levels 31, 63, 95 and/or 127 logs in.
Problem: [User Administration] Current authorization group 1-4 variables bits are not correctly set in Service Engine v10 32-bit when a user with authorization levels 31, 63, 95 and/or 127 logs in. As a result, the respective variable shows ...
Checklist: WVS does not work
Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Perform a build update to the latest version. In the ...
It is not possible to edit the user group's authorization levels in the runtime.
Summary In the runtime, it is not possible to edit a user group and change the authorization levels for the group. An Admin user should be able to edit user groups and set authorization levels for the user groups. (only those authorization levels ...
Using AddIn in combination with WVS
Can AddIns be used in WVS? Simple answer: yes, but... Types of AddIns, Types of WVS There need to be distinguished between a AddIn Service and an AddIn Wizard. Whereas the first is started and stopped and reacts in between on events is the latter ...
SAP maintenance reports don“t work
Summary In the module SAP interface it is possible to define maintenance reports. They actually use the SAP function blocksĀ ALM_PM_MAINTNOT_CREATE ALM_PM_MAINTNOT_SAVE ALM_PM_MAINTNOT_MODIFY_DATA These are, however, not remote enabled with a ...
