Wrong Variable IDs in Metadata-Table is imported from another project
The problem was caused by the virtual variable dependency check: this check did not recognize self-assignment of calculated variables. The check has been extended to prevent such situations. For existing databases that face this problem, the workaround has to be applied to get them working again.
Change Variable IDs inside the Database-Table to the ones corresponding to variables in the current project
Issue Number: 200953
Fixed on Date: 29.10.2019
Versions: zenon Analyzer 3.30 0 BUILD 65735
    • Metadata Synchronizer has Low synchronization performance with certain workspaces
      Summary In version 10 and 11 the synchronization process for the Metadata Synchronizer has been optimized, Description In some workspaces the Metadata Synchronizer needs a lot of time to load and synchronize all data.  The synchronisation process has ...
      Summary The performance of the synchronisation process in the Report Engine was improved by these steps: The synchronisation of those items was optimised (affects all computers regardless the number of processors): Links from archives to equipment ...
    • Language table wizard corrupts project
      Summary Running the Language Table Wizard corrupts the project. This has been fixed. Description The Language Table Wizard causes errors when run with the options "Convert texts into keywords" and "Linked symbols". The entries in the language table ...
