Wrong error message ALC: Elements without connection to a source" when you have the same link on multiple screens"
global ALC checks are done after compiling each screen causing false positive errors
Issue Number: 142808
Fixed on Date: 10.4.2019
Versions: 8.00 0 BUILD 57280
ALC source can not be deleted permanently
Summary Error message pops up after deleting an ALC source and reopening configuration dialog without project unload/reload. Description Error message pops up after deleting an ALC source and reopening configuration dialog without project ...
FAQ: What can I do if the Service Engine does not start or is closed with an unhandled exception and the error message "(InitInstance (); an unnamed file has a bad format)" or "Init Instance (): an attempt was made to access an unnamed file past its end" is shown?
This issue may occur due to missing digital certificates on the system where the error appears. Microsoft Windows implements a mechanism that automatically downloads, over the internet, trusted root certificate authorities, which are not installed ...
The ALC.xml file does not contain the linked NodeID for ALC link elements when the link is used in another screen
Summary When an ALC "link" element is used in different screens, on one of the connected lines, the linked NodeID information is missing in the ALC.xml. DescriptionWhen an ALC "link" element is used in different screens, on one of the connected ...
ALC property 'Source for reverse feed' - IDP_DYNELE_ALC_REVSRC - demands license for Topology Module while 'Transformer' not.
Summary The ALC property "Source for reverse feed" - IDP_DYNELE_ALC_REVSRC - is only available, with license of Topology Module (extended ALC). But the ALC element 'Transformer' is available without Topology license, e.g. in the zenon Energy Edition. ...
