Wrong edit and insert behavior in Screen Archive revision for Service Grid Data Storage evacuation
The archive revision screen functionalities are now correctly enabled/disabled based on if the archive file is already evacuated to Data Storage or not. Additionally: based on the wrong detection, the save changes function was also not working properly before. Now, this also works the same as for SQL evacuation.
Issue Number: 241942
Fixed on Date: 30.11.2021
Versions: 10 0 BUILD 92805
FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
How to use the IIoT Dashboard Service
In this article you will get an overview of how to use the Dashboard Service with data from the zenon Service Engine. This service is available with IIoT Services 14.1. Prerequisite: You have connected a Service Engine to the IIoT Services and you ...
