wrong default filter setting for file format wne selecting a project.ini file
The startup tool allowes to select a start project for the runtime. For this, you need to browse to the project.ini file of the desired project in the 'RT-path' property. Unfortunately, with default settings the ini file will not show up in the file selection dialog because the file type filter is set to 'v6/v7 (project.ini). Only after setting this filter to 'v5 (*.ini)' the project.ini file will be shown.
The default filter setting is now '*.ini' so the project.ini files will be shown correctly without any modification to the filter being required.
Issue Number: 30427
Fixed on Date: 26.9.2013
Versions: 7.11 0 BUILD 10238
