wrong colors in Batch control recipes
In some situations it can happen that batch control PFC recipes are displayed with wrong grid color when the grid color was modified manually.
An issue has been addressed where wrong colors were used for the grid of a PFC recipe in the Batch control module. After the fix, correct colors will be used to display the grid.
Issue Number: 31419
Fixed on Date: 19.3.2014
Versions: 7.20 0 BUILD 17768
    • BATCH CONTROL - Function authorization for export of recipes
      Summary Batch Control now has a new function authorization for exporting recipes. Description The export of recipes in Batch Control also allows access to the device's file system. This can now be restricted. For this purpose, the setting "Batch ...
    • Importing Batch Control recipes with illegal name is possible
      Summary In Batch Control recipe's names may not include some special characters. However, wen importing recipes from XML files, there is no check to prevent the use of these characters. Description In Batch Control recipe's names may not include some ...
    • Validation of Batch Control recipes takes very long
      Summary In Batch Control recipes can grow very large. The larger and the more complex a recipe is, the longer the Validation takes. Recipes with more than 1000 phases and lots of branches and loops may require several minutes for validation. ...
    • Validating large Batch Control recipes may take very long
      Summary Validating very large and complex Batch Control recipes (e.g. with big Matrix operations in a loop) may tke an excessive amount of time. During this time the runtime can't be operated. Description Validating very large and complex Batch ...
    • Opening a Batch Control Screen may take very long if many recipes exist
      Summary When opening a Batch Control screen, properties of existing recipes are loaded in order to display this information in the list. Depending on the number of existing recipes and configuration of the screen switch function this may take a while ...
