Writing a value through a .wpf element to an internal variable is not possible when authorization in the network is enabled and the system does not have the authorization token.
When using a .wpf element, writing a value through the element to a local internal variable is not possible when network authorization is used and the system does not have the network token. Using other dynamic elements or using functions, writing to a local internal variable is possible even without the network authorization token being present.
An issue has been addressed in the .wpf element where the checking of the network authorization token did not make an exception for local internal variables.
Issue Number: 37631
Fixed on Date: 22.12.2016
Versions: 7.50 0 BUILD 34636
