Writing a string variable of the straton_NG driver in the zenon runtime with a length of 247 characters or more fails and prevents further writes to the string variable from the zenon runtime until after a restart of the runtime
When a string variable in zenon (lenght 255) from the straton_ng driver is written in the runtime (string lenght in zenon logic 255), writing 246 characters still works OK.
However writing 247 characters is not accepted (string is not updated in the zenon logic) and any further writes to the string variable, even with just one character, no longer updates the string variable in the zenon logic. If at this stage the string variable is updated in the zenon logic, the variable is correctly updated in the zenon runtime, but it still cannot be written in the zenon runtime.
After a restart of the runtime, the string variable can be written again.
Problem was addressed in the function to write variables. The maximum possible telegrammlength is now used.
When using strings with the maximum length, it is recommeded to set in the connection setting of the driver the max. write request length to 1024 instead of 512
Issue Number: 31516
Fixed on Date: 6.3.2014
Versions: 7.10 0 BUILD 11355 | 7.20 0 BUILD 17768
When writing a string with more than 222 characters to a variable of type string of the STRATONNG driver, the STRATONNG driver stops working.
Summary When writing either from the zenon runtime or zenon logic a string with more than 222 characters to a variable of type string of the STRATONNG driver, the STRATONNG driver stops working. DescriptionWhen writing either from the zenon runtime ...
When writing string variables of MODRTU32 driver, the last char of a string is not sent by the MODRTU32 driver, when the length of the string is uneven.
Summary The MODRTU32 driver does not send the last character of a string variable which length is uneven. E. g. writing the string "ABCDE" (5 characters -> uneven) results in the string "ABCD" in the slave. DescriptionThe MODRTU32 driver does not ...
Modbus Energy driver writes random data after the 0 termination for the string
Summary When writing a value "abcd" in the runtime to a string variable with a length of 130 characters of a modbus energy driver, the string abcd is written with null termination, followed by random data for the rest of the string length, if the ...
