Write set value via Element only allows as many digits as element is wide when using a numeric variable with Numeric Value or Dynamic Text field - SE
If a numeric variable with numeric value and Dynamic Text elements is used for "Write set value via Element", the number of allowed digits is arbitrarily limited. The limit is set in the Service Engine by the actual width of the element.
This behavior has been changed. The number of possible digits of a number is no longer limited by the width of the element.
Item ID: 262041
Version: 11.00 Build: 126436
