"Write set value/change by" property of the "Numerical Value" object does not allow to set a value less than variable measuring range min
The screen element “Numerical value“ does not allow to set a value for the property "Write set value/change by" that is outside the measuring range of the linked variable. In this case, the entered value is always increased or decreased by the measuring range of the variable. In previous versions, the current value was always offered as a default value, which was not corrected with the measuring range of the variable.
This behavior has been changed. It is now possible again to select a value that lies within the measuring range delta of minimum to maximum value.
  • Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Item ID: 247210
Version: 11.00 Build: 115310
Version: 10.00 Build: 94554
Version: 8.20 Build: 94608
