With the System Text Wizard not all parameters of the ‘User administration windows’ will be updated.
If the function called ‘Change user’ (User administration -> Change user) will be executed at the zenon Runtime it may occur that the parameters ‘TRUE, NONE and FALSE’ will be not updated into the language which was chosen before.  These words are already added to the language table manually but not recognized from the ‘System Text Wizard’ by importing all system words.
An issue has been addressed at the ‘System Text Wizard’ import. Now, it works proper and also the parameters at the columns will be translated into the chosen language at the ‘User administration Windows’ which will be executed with the function ‘Change user’.
Issue Number: 34666
Fixed on Date: 16.11.2015
Versions: 7.60 0 BUILD 36068
