Windows CE device does not display historic data in AML
Windows CE device does not display historic data in Alarm Message List, it displays "Seek failed" error message instead.
Found issue in MFC CFile::Seek and implemented a work-around.
Issue Number: 34334
Fixed on Date: 30.4.2015
Versions: 7.10 0 BUILD 20049 | 7.11 0 BUILD 19853
FAQ: Windows CE not supported anymore with zenon! What are the main reasons and what do I have to consider? Is zenon not able to run on Windows CE anymore?
The support for zenon Windows CE Versions was frozen with the zenon Version of 7.20. This means that in any higher zenon version, the CE Version delivered with the Setup is a zenon CE Version of zenon 7.20. There are no more functional enhancements ...
FAQ: Update CE proceedure
Checklist: Update CE fails
After reloading the runtime on a Windows CE device, alarms and events dissappear from the list.
Summary After compiling all runtime files, transferring the runtime files and reloading the runtime on a Windows CE device, all current alarms and events are no longer displayed in the list DescriptionAfter compiling all runtime files, transferring ...
FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
