When wrong configured Profinet driver stops the zenon Logic Runtime, the IEC61850 Server driver hangs
Circumstances under which this can happen:
zenon Logic (straton) project has Profinet driver and IEC61850 Server driver
the Profinet does not have correct Adapter identification so cannot start
the iec850 server has all settings OK.
Issue behavior:
zenon Logic (straton) Runtime does not start but hangs. The zenon Runtime cannot start until Logic RT is killed.
Issue behavior:
Issue was addressed in timing for thread termination.
Issue Number: 28119
Fixed on Date: 7.11.2012
Versions: 7.00 0 BUILD 5
Interface settings for using an Ethernet port for Fieldbus communication in zenon Logic (e.g. ProfiNET)
When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
Some drivers, e. g. MODRTU32, cause the zenon Logic runtime to show unexpected behaviour when running as IEC 61850 server when the driver connectes to the listening port of the IEC 61850 server within the zenon Logic runtime.
Summary When the zenon Logic runtime is running as a IEC 61850 server, the connection attempt of some drivers, e. g. MODRTU32 to the listening port of the IEC 61850 server within zenon Logic results in an unexpected behaviour of the zenon Logic ...
The Weihenstephan client driver in the zenon logic stops working if for a LIST in the Weihenstephan client driver more than 256 tags are configured
Summary When in a LIST in the fieldbus configuration for the Weihenstephan client driver more than 256 tags are configured, the Weihenstephan client driver stops working in the zenon logic runtime. Description When in a LIST in the fieldbus ...
