When starting an external tool in the zenon startup tool, the first parameter set in the command line, is ignored.
In the zenon startup tool the external tools can be started with certain parameters in the command line. The first parameter is ignored.
The issue has been resolved and now the first parameter is taken into account and applied when starting tools via the command line in the startup tool.
Issue Number: 26044
Fixed on Date: 2.2.2016
Versions: 7.60 0 BUILD 37399
    • CD_SVA_2025_01: zenon Remote Transport Vulnerability
      What you should know The vulnerability targets a specific function of the zenon Remote Transport Service. The underlying weaknesses is CWE-306: ‘Missing Authentication for Critical Function’. The versions listed below are affected by this ...
    • AccessMODBUS: Process Gateway cannot be started via startup tool
      The Modbus Process Gateway (AccessMODBUS) could not be started via the Startup tool. The issue has been addressed and the start via the Startup tool works again now. To benefit from this fix: Update your zenon Software Platform to the latest build of ...
    • Platform Setup 11: Comparison Tool starts with "Unhandled UI Exception" popup error
      Description When starting the Comparison Tool from the Startup Tool, an "Unhandled UI Exception" is displayed. The Comparison Tool cannot be started. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the ...
