When Standby gets Server, Message Control active status is reset to the default project setting
When Standby gets Server, Message Control active status is reset to the default project setting instead of the currently used Message Control mode.
Message Control redundant operation was modified so the current state also is taken over when a redundancy switch occurs.
Issue Number: 31059
Fixed on Date: 18.12.2013
Versions: 7.20 0 BUILD 17768
