When rotated elements are used in a screen, elements look like in the editor when the runtime is started in the present resolution. If "adjust to monitor resolution" is used, the same elements are not displayed correctly anymore.
An issue was addressed in the monitor administration that made it possible for the user to change aspect ratio between editor and runtime. This behaviour now changed so the aspect ratio keeps the same when resolution is changed. Now, on the bottom or the right side, there will be unused space depending on the aspect ratio of the frames used.
Fixed on 24.04.2012, available from 7.00 SP0 Build 1
Issue Number: 25092
Fixed on Date: 24.4.2012
Versions: 7.00 0 BUILD 1
