When opening the VBA IDE and double-clicking the MyWorkspace class, there is no code being shown. This causes side-effects, e.g. the linked symbol wizard is not starting because it reacts on the OnElementDoubleClick event which is fired by ZenWorkspace.
An issue was addressed in the setup deployment of the ZenWorkspace.vba file. Please note that the ZenWorkspace.vba (which contains the MyWorkspace class) is only overwritten if there is no code inside. If code has been added to the class manually, it will not be overwritten by the setup.
