When having a project in zenon logic with a local variable which has the STRATON Profil activated and then copying the zenon logic program, an error message appears
When a zenon Logic Program containing variables with profiles is copied, these variables were copied correct without misleading error message.
Assign the STRATON profile to variables after copying the program in zenon logic
Issue Number: 108014
Fixed on Date: 14.5.2018
Versions: 7.60 0 BUILD 49005 | 8.00 0 BUILD 48821
zenon logic: Unexpected complex data in expression
In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
Project in zenon Logic takes long time to compile and eventually Stops responding.
Description A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects. This error has been fixed. Compiling a ...
Deleting of an Referenced Smart Object Template causes Zenon to Crash
Checklist: Message Control
Checklist: The Logic Service to Service Engine connection does not work
Time estimate: 30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
