When creating new straton projects or changing the communication parameters in the zenon logic runtime settings, this settings are not correctly applied to the Driver.
When creating new straton projects or changing the communication parameters in the zenon logic runtime settings, this settings are not correctly applied to the driver. When opening the driver configurtion the settings are always overwritten with the Defaults.
An issue has been addressed in the serialisation of the driver settings
Issue Number: 24054
Fixed on Date: 27.2.2013
Versions: 7.10 0 BUILD 5560
    • Checklist: The Logic Service to Service Engine connection does not work
      Time estimate:   30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
