When an existing interlocking is exported and afterwards imported again the name of the interlocking changed.
If you have provided an interlocking with a specific name e.g.: term, this name will be changed after export and import via XML.
An issue was addressed where the created interlocking during export and import via XML. Now the interlocking is considered correctly and the name is retained.
available with 7.00 SP0 build 13
Issue Number: 30547
Fixed on Date: 21.10.2013
Versions: 7.00 0 BUILD 13
