When an element is added to a symbol by using the API, the resulting position/size of the added element is incorrectly
When trying to add elements to a symbol, there is a position offset added to elements which results in a wrong position/size. Setting element positions to 0/0 before adding element to symbol does not fix the problem.
This may also results in elements of symbols to appear outside of a symbol.
An issue was addressed in the symbol handling. Now, the closing of the symbol rectangle will be calculated correctly.
Issue Number: 26640
Fixed on Date: 20.12.2013
Versions: 7.00 0 BUILD 16 | 7.10 0 BUILD 5560
Under specific circumstances when resolving a symbol, elements in the symbol change their position
Summary When resolving an element in a screen in the editor, under specific circumstances the elements in the element group change their position Description When resolving an element in a screen in the editor, under specific circumstances the ...
Buttons contained in symbols from symbol library are always display in black if symbol is used in combined element
Summary Buttons contained in symbols from symbol library are always display in black if symbol is used in combined element Description Buttons contained in symbols from symbol library are always display in black if symbol is used in combined element ...
Set colors of color palette to zenon elements via API.
Colors in zenon are a 3-byte code of RGB values. The value #EB29D6 corresponds to a strong pink tone. If these colors are linked directly to a zenon object exactly this value is entered in the dynamic property of the element, screen, textcolor, ...
The history of changes may not log a screen element position change in the editor.
Summary Despite the detailing level is set to "object", the history of changes may not log the change of a screen element position when using the "position" properties in the editor. DescriptionDespite the detailing level is set to "object", the ...
