When a zenon driver behaves unexpectedly, the dialog saying that a dump file is written including the location of it is sporadically not shown.
The dialog saying that a dump file is written including the location of it is sporadically not shown when a zenon driver behaves unexpectedly.
This issue has been addressed by making the resource file which is responsible for the exception dialog available for every zenon driver.
Issue Number: 37774
Fixed on Date: 30.1.2017
Versions: 8.00 0 BUILD 46644
Checklist: zenon Driver does not start in zenon 11 Engineering Studio / Service Engine.
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenDrvOpsManager is no longer ...
The BECKHNG Driver do not import the Variables from the .tpy File
Summary Changes in the TPY file format can lead to circular references in the BECKHNG driver. Variables with circular references cannot be imported. Description The BECKHNG driver refuses to import variables from the TPY file. This happens because of ...
