Werum MSI Interface AddIn is not running in zenon 11
The Werum MSI Interface AddIn does not work in
zenon 11 if the simulator is not running on the same computer. If an IP is defined
that is not on the same computer, the web server contained in the AddIn will
not start.
This error has been fixed.
To
benefit from this fix:
- Update
your zenon Software Platform to the latest build of zenon 11 or higher.
Item ID: 256270
Version: 10.00 Build: 108506
Werum MSI Interface(AddIn): Wrong state value is written to variable after receiving message
Description In Werum MSI Interface, an incorrect status is written to the variable after receiving a message. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the latest build of zenon 12 or higher. Item ID: ...
Using AddIn in combination with WVS
Can AddIns be used in WVS? Simple answer: yes, but... Types of AddIns, Types of WVS There need to be distinguished between a AddIn Service and an AddIn Wizard. Whereas the first is started and stopped and reacts in between on events is the latter ...
zenon to PAS-X MES connectivity solution
Summary Bidirectional exchange of data between Werum PAS-X and zenon Description The Werum MSI Interface enables the bidirectional exchange of data between Werum PAS-X and zenon. Werum PAS-X can thus use zenon to directly access the production ...
