WebEngine Docker Image loads cert bundle from wrong location
The HTML Web Engine cannot establish a connection under Linux. The cause is that the certificate bundle is loaded from the wrong location in the Docker image. Even if the environment variable is configured correctly in the container, appsettings.docker.json refers to the wrong path ".../app/certs/ccb.scadacert".
This error has been fixed. The correct path is used again.
Item ID: 246689
Version: 10.00 Build: 92805
    • FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
      Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
    • Historian On change archive in start image stores wrong time
      Summary 'On change' archive in start image stores variables having internal time stamp with wrong time. Description'On change' archive in start image stores variables having internal time stamp with wrong time. Solution Time for a record is now taken ...
    • WebEngine docker build uses not supported environment
      Description Docker-compose v1 is not supported any longer. For this reason, building docker on Windows was not possible on new buildservers. The issue has been fixed with a native build in linux with a docker build. How to benefit from this fix: ...
    • Checklist: HTML Web Engine
      Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
