Web Visualisation Extended trend when curve not visible y axis is still visible
If a curve has been added and removed via the curve visibility variable in the WVS Trend, the axis stayed visible. In addition, the scales were not correct.
The issue has been fixed and the behavior is now as expected.
Update your zenon Software Platform to the latest build of zenon 14 or higher.
