Web Engine Compiler - OutofMemoryException with a specific customer project
In certain constellations, the Web Engine Compiler terminates with an "Out of Memory" exception. The cause is that the Web Engine Compiler is running as a 32-bit application.
This has been modified. The Web Engine Compiler is now a 64-bit application. This also requires a 64-bit operating system.
  • Update your zenon Software Platform to zenon 10 or higher.
Item ID: 259159
Version: 10.00 Build: 125767
Version: 11 Build: 126436
