VoIP call is not possible because of authorization issue.
Some providers are not so flexible with the MC VoIP authorization management. It is possible that there are some providers which use for the "realm" not their domain name.
The authorization is now more flexible on the MC VoiP side. Now MC VoIP will always use the same "realm" name as it is used by the provider in the authentication "challenge" SIP request, so that the authentication will always work independend from the "realm".
Issue Number: 37757
Fixed on Date: 30.1.2017
Versions: 7.50 0 BUILD 36072
FAQ: Message Control || VoIP message is sent but can’t be heard
In a VoIP message the audio file can use several codec formats for its compression. When a call is set up, then sometimes some target providers already play back the ringing to the call as an audio stream. This can be done in several or one specific ...
[User Administration] Current authorization group 1-4 variables bits are not correctly set in Service Engine v10 32-bit when a user with authorization levels 31, 63, 95 and/or 127 logs in.
Problem: [User Administration] Current authorization group 1-4 variables bits are not correctly set in Service Engine v10 32-bit when a user with authorization levels 31, 63, 95 and/or 127 logs in. As a result, the respective variable shows ...
Messagecontrol: VOIP message is not forwarded to the subsitute person or in a following call when the first person in charge is not responding (no reaction)
Summary VOIP messages in Message Control are not forwarded. This behavior has been fixed. Description In Message Control, if a VOIP message is not not answered by the first person called or the call is answered by an answering machine, then the call ...
K5B: document the PRJTOUTF8 call in help
Description In zenon Logic the PRJTOUTF8 call was missing in the help and has been added. The issue has been addressed and K5B PRJTOUTF8 <ProjectPath> call has been converted to UTF8. To benefit from this fix: Update your zenon Software Platform to ...
Message Control sending method Following Call and Endless Call do not work properly
Summary When the sending method Following Call and Endless Call are used in a Message Control Send Message function, the group is not run through. The Message Control MDI screen reports that an error during sending has occurred, although a message ...
