Variables with a comma in the name (multi-dimensional arrays) can no longer be used in the OPC UA Gateway
Variables with a comma in the name can now be used again in the OPC UA server in the process gateway
Renaming the variables, using allocations or using the ADP driver, may provide a workaround to avoid having to use variables with a comma in the name, in the OPC UA process gateway.
Issue Number: 136532
Fixed on Date: 7.6.2018
Versions: 7.50 0 BUILD 49034 | 8.00 0 BUILD 48821 | 7.60 0 BUILD 49005
How to setup the zenon OPC UA Process Gateway with a self-signed certificate
This article describes how to create a self-signed certificate for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use certificates for OPC UA ...
How to setup the zenon OPC UA Process Gateway with a CA-signed certificate
This article describes how to create a certificate signed by a Certificate Authority (CA) for using it with the zenon OPC UA Process Gateway. For general information about certificate usage for OPC UA security, please refer to the article How to use ...
OPC-UA Server: DNS Name used in certificate created by zenon.
Report Engine: Support multi-dimensional array variables
Summary Report Engine supports multi-dimensional array variables. Description Up to and including version 11, multidimensional array variables in Report Engine were not supported. Cause: In zenon, multidimensional array variables use up to 3 ...
