Variables from the STRATONNG driver receive status INVALID when performing an online change in the zenon logic
When performing an online change on downloading a new zenon logic project to the zenon logic runtime, variables from the STRATONNG driver become INVALID. Variables from the STRATON32 driver remain spontaneous
When using the event mode of the new STRATONNG driver, an online change is automatically detected, compared to the STRATON32 driver where this went unnoticed. The STRATONNG driver now no longer sets the INVALID status for the reconnect time.
Issue Number: 29684
Fixed on Date: 3.6.2013
Versions: 7.10 0 BUILD 6571
    • FAQ: How can I monitor and react on the communication status of my devices with zenon?
    • EIP Scanner: Performing Online change in zenon Logic causes the EIP communication to break
      Description In zenon Logic the Ethernet/IP Adapter aborts the communication when online changes are performed in the Ethernet/IP Scanner. The communication cannot be restored. This error has been fixed. If the connection is interrupted, it is ...
