variables cannot be sorted by the identification column if a language switch is configured.
When sorting variables in a list in the Service
Engine, sorting by the Identification column does not work correctly once language switching is configured. In this case, the keywords from the language table
are used for sorting instead of the identification.
This behavior has been modified. Sorting is now done by identification, even if language switching is active.
- Update your zenon Software Platform to the latest build of zenon 8.20 or
higher.
Item ID: 268685
Version: 12.00 Build: 180966
Version: 11.00 Build: 162879
Version: 10.00 Build: 162215
Version: 8.20 Build: 162748
Button as switch shows invalid state before a variable value is available
Summary A button element configured as a switch displays an invalid state in the Service Engine before a variable value is available. This behavior has been modified. Description When a screen is opened in the Service Engine, a button element that is ...
Cel print with Switch language in Sub Project from Integration Project doesn’t work.
Summary Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified. Description In a project, the CEL is configured for ...
Variable identification in the Variable Diagnosis screen cannot be translated in Subproject from Integration project
Summary In the Service Engine, not all variables are translated as configured in the Variable Diagnosis screen. This has been fixed. Description In the Service Engine, with Multi Project Administration, the identification for variables from the ...
